path1
Jun 08, 2017Explorer
Reading for you.
(don't be surprised if pic's don't exactly match yours. My 01 came with lift pump inside tank and others same year the pump on frame outside of tank, depends on day it was made I guess? But you'll get idea of what they had in mind.)
If you need pump... he (Eric) is close to you in Battleground. That is if you're broke down where your sig line says. Good guy and knows his stuff. Many people carry as spares. http://www.vulcanperformance.com/Carter-Replacement-Lift-Pump-03-04-Dodge-p/p76110.htm
http://www.cumminsforum.com/forum/94-98-powertrain/510197-bad-injector-pump-symptoms.html
http://www.cumminsforum.com/forum/94-98-engine/58777-joe-gs-fuel-system-writeup.html
(Edit part)... If your rig is running I would NOT drive to his place. Don't think a Class A will make it across creek. He likes phone calls first anyways.:)
38,782 PostsLatest Activity: Sep 10, 2026
