Tom/Barb wrote:
smlranger wrote:
wolfe10 wrote:
When you changed the fuel filters-- what did you find?
Fuel poured out of any of my filters has looked absolutely fine.  I have not cut any filter open yet.  I always store the coach with a full fuel tank and I have been treating the fuel with BioBor (just in case) for the past year.
My issue this trip started after getting 50 gallons of fuel at a very busy Pilot and after driving over some really rough road in LA.  That led me to suspect something stirred up in the tank.
I talked to my local Cummins shop in VA and they told me that some folks had reported similar issues and had switched their secondary filter to a 10 micron filter and the problem went away.  My secondary fuel filter head has 7/8" stud and I have not yet located any 10 micron filters that will fit that head.  My Fleetguard FF5636 is 2 micron.  My primary filter is 10 micron.  A friend with an ISC read a Cummins tech bulletin about fuel starvation on ISC's with 2 micron filters and recommended changing to 10 micron.  He has done that and his similar issue went away.
I do not have any issue with oil consumption.  I have never had to add oil between annual service except last year when I had a leaking valve cover and gear cover.  That was fixed at Cummins.
When I had the coach at my local Cummins shop last year for the oil leaks, they were aware of the previous issue I had with low fuel pressure.  They said they checked over everything and found no obvious issues.  They ran the coach on their dyno for 3 hours and it ran fine.
I have never had any overheating issues.  My coolant temp runs 186-188 until hard pulls when it may reach 195 for brief periods.
No chips.  This is a bone stock 425ISL clean diesel (DPF).
In that case, forget the engine contaminating the fuel system, (our problems are not the same)
 The 2 micron filters clog very easy.  2 micron is .0.00007874015748031496 inches. that is 98% of the particles bigger than that will be trapped. Many have gone to a 10 micron, and have no problems.
I have been browsing the net.... Baldwin, Wix, Donaldson, Fleetguard and I have not been able to find any 10 micron fuel filter that has the 7/8" stud opening.  The best I've found is a Donaldson rated at 5 micron.  I may see if the folks at Cummins El Paso will replace my secondary filter head with the head with 1" stud which gives me a lot of filter options.
