dougmac
May 25, 2013Explorer
2007 and later engine I am guessing? What was the code? Is it a sensor out of range code or "Crankcase Pressure - Data Valid but Above Normal Operational Range" code?
If it is the "Crankcase Pressure - Data Valid but Above Normal Operational Range" you probably need to service the crankcase breather filter.
If it is out of range, you have a bad sensor or an intermittent wiring fault.
Doug
Doug
38,782 PostsLatest Activity: Sep 10, 2026
