Duramonster
Dec 03, 2015Explorer
8.3 Cummins low oil pressure at hot idle
My 8.3 Cummins has low oil pressure at hot idle . I installed a mechanical gauge on the engine to make sure that it wasn't the dash gauge. It idles at around 8 to 10 Lbs. when hot . As soon as you bring up the idle to around 900 RPM ,it goes up to around 20 Lbs. and increases with RPM. At cold start , the pressure is right up where it should , but as the temp goes up, the pressure goes down. Engine sounds good and has been like that since I purchased it.
