dougmac
May 25, 2013Explorer
imgoin4it wrote:
Worst case of a high pressure in the crank case I have heard of was caused by blow by at the valve stems and cylinder liners. The real cause was that the engine was "dusted" due to not securing the air intake and air got into the engine with out going through the air filter. Dust "sanded" and increased all the tolerances causing pressure in the crank case. The dirty air also "ate up" the turbo blades. This was on a brand new coach that came from the factory with the loose air intake hose. A big problem that no one wanted to stand behind as it was a "maintenance issue". It was finally resolved and fixed but was a real mess. Suggest you do whatever you must to get the problem identified and resolved. The bill to fix the one I know about was about $30,000.
With internal engine problems you would see a "Crankcase Pressure - Data Valid but Above Normal Operational Range". the op is seeing invalid data from the sensor so there is no indication that he has an internal engine problem.
When I have seen problems with either rings or valve guides, you will have a "Crankcase Pressure - Data Valid but Above Normal Operational Range" code. Servicing the crankcase breather filer will usually bring the crankcase pressure back into the normal range. As an internal problem develops, you will see the crankcase breather filter needing to be serviced more frequently.
Oil analysis is by far the best way to detect an intake leak and prevent damage to the engine.
38,782 PostsLatest Activity: Sep 10, 2026
