JR45
Mar 29, 2015Explorer
In the (ECONOMY MODE)it can turn into a dog on some grades.It can make a BIG difference in rolling hills. If you are in rolling hills and regular mode (particularly with the cruise control on), it is common for the transmission to shift down to 5th on the uphill and back to 6th on the downhill. Repeat this process hundreds of times. In economy mode, you will stay in 6th gear unless the hill is so steep or so long that the engine can not pull it without dropping below peak torque RPM.
Every time you start the coach, the transmission is in regular mode. This is the default setting. IF you push the mode button, it goes to "economy mode" AND the light illuminates, your coach may of had the default settings changed.
JR
JR
