Rbell70669
Jun 24, 2018Explorer
Cummins Onan wont start
I have a Jayco, Melborne 24M that has a Cummins Onan RV RG 3200 generator. We have had the rig since the beginning of June and it has started fine untill recently. I went to start it and after it began to start it quickly shut off. The panel said "Oil Temp-Press". Dip stick shows oil within operating range and since the unit had not started I don't believe the temperature is the issue. After attempting another start a "Gen Alert" was displayed.
During the course of looking over the unit and the manual I found the ground connection to be loose, so it was tightened. I also notice the wire housing the comes from the generator has a significant crimp in it just before it enters a junction box just a few inches from the generator.
Anyone have any suggestions? I have called the Good Sam service line and the two different Tech's I spoke with could not provide any info.
