Trumpet_Player
Apr 05, 2016Explorer
If I understand your question correctly, you are trying to determine just how much capacity you have left if you run the coach at the full GVWR of 22,000 lbs. Well, you have a GCWR (gross combined weight rating) of 26,000 lbs. The math tells us that you have a 4000 towing capacity if you run the coach at 22,000 lbs. Why they placed an 8000 lb capacity receiver/hitch on the coach is anyone's guess. I don't believe you could run the coach light enough to ever use the 8000 lb capacity.
