Chum_lee
Oct 10, 2023Explorer
Mike Schriber wrote:
I've noticed that the hoses for my hydraulic leveling system are losing the outer rubber protective later. It's just cracking and falling away. Beneath I can see a woven layer that I imagine is what contains the pressure of the inner hose. The woven layer looks pristine.
Do I need to immediately worry about replacing these hoses or can I monitor them for deterioration of the now exposed pressure layer?
Thanks!
The most important layer of your hydraulic hoses is on the inside where the fluid is. Which you CAN'T see. Nor can anyone else with the hoses in place. That said, often (not always) what's happening on the outside, reflects what's happening on the inside. Your flexible hoses are at least 17 years old. IMO, the hydraulic system for your levelers isn't critical, like it is for brakes/steering/cooling/lubrication. It's more of a convenience that, in a pinch, you can make do without. If it were mine, I wouldn't worry about it, BUT, I would source/price replacement parts, and be clear on the availability. If you plan on replacing the hose(s) yourself and the prompt availability is questionable, I would order the hoses now and keep them (along with extra hydraulic fluid) on hand for the impending moment. All hoses fail, . . . eventually. At the first sign of fluid seepage, bulging, or, lack of hydraulic pressure, IMO, the best time for hose replacement has arrived and passed. Your decision. IMO, it's more a matter of how much inconvenience you're willing to tolerate.
Chum lee
P.S.: When I say, "I wouldn't worry about it." That doesn't mean I wouldn't take action, . . . . . now. My mother (RIP) used to worry incessantly, doing nothing, as she watched her world fall apart. I'm not suggesting you do that!
38,783 PostsLatest Activity: Sep 23, 2026
