dodge_guy
Oct 11, 2023Explorer II
I replaced all of my hoses last year, I also have hydraulic slides. Went to Pirtek where I got much stronger (higher psi) and better hoses.
Cost me $1800 but well worth it. You’ll want to do them ASAP because if a hose blows you will have fluid everywhere! On my failure it was after a very hard dip on the highway which pushed the slide out out a bit and ruptured what was probably a bad hose (blew at the pump). The pump ran for hours till I realized what it was doing. The. I learned that the system requires pressure for the pump to turn off.
This year the pump failed because of that failure. Pump is $1000!!!!!
Replace them all now with higher quality hoses and not those from LCI/Lippert!
38,782 PostsLatest Activity: Sep 10, 2026
