kmb1966's avatar
kmb1966
Dash A/C blows out of defrost when climbing or head wind
My dash a/c blows cold air, but at times when climbing hills/overpasses or traveling in a head wind, the air will decrease out of the vents, and blow out of the defrost vents. Upon slowing down, the air will return to the front vents. I've brought it to nearly every shop in town, with most scratching their heads after replacing lines and check valves and saying 'just live with it'. No. I don't want to live with it. I want it to blow out of the front vents. I've heard (on this forum) that a secondary vacuum pump could be added to solve this problem. My question is WHERE do I find this pump, and WHERE would it be installed? I'm clueless on where I would put this auxiliary pump for additional vacuum. :h
2000 Ford F53 Chassis
  • Yes, I fixed one of those a few years ago. In that case someone had done some work and covered the line going to the reservoir with something that wore into it.
  • Probably leak in a vacuum line. A good Ford truck mechanic can find it.
