- Bill_S_1ExplorerFound it. The tag on the compressor reads TAMA MFG. TM-1-16HD, 0630-9034. I will post up the source later in the week, if you need it.
- Bill_S_1ExplorerI just replaced mine in early July. I got under there with a few rags, and cleaned it off so I could read the metal tag part number. actually used my cell phone camera to take a pic of the tag, as it was on opposite side. Called arou d and searched internet. Found a Florida A/C wholesale seller, and bought a new, oem compressor for about $200
Don't have access to the info until end of the week, if that helps. - gatorcqExplorerThis compressor is installed on many CAT 3126E / Freightliner Rig, not just Alfa. In fact this photo is from a different rig.
FL wants $700, for one. There is no P/N listed on it and yes it looks like a Sanden. So I am looking for someone who has actually replaced one or knows the P/N.
thanks for the help - wolfe10ExplorerBe sure to check the automatic belt tensioner while you are in there. It is a common failure rate part and can adversely affect alternator and A/C compressor bearings.
http://www.youtube.com/watch?v=uTLV5IU_IMM - dakdaveExplorerremove it ,should have a sticker on it with name and part number. Looks like a sanden compressor
- Big_KatunaExplorer IIYou might have better luck at one of the Alfa See Ya owners groups/forums. There is one on IRV2 and others. It won't be a CAT item, it will be a Denso or some other AC maker. There is probably a number on it you can google.
- Mandalay_ParrExplorerTry the chassis mfgr. They are the ones who installed it.
