wolfe10
Jun 09, 2014Explorer
dougrainer wrote:
The OPs question is NOT do Dash Ac's drip water. The question is, do they drip water under a Diesel Engine in the REAR OF THE MOTORHOME WHERE THE ENGINE IS LOCATED, where there is NO Evaporator,Condensor/Receiver dryer/Expansion valve, only the lo and hi lines. While the low line can indeed sweat at the compressor, the HEAT of the engine and engine compartment will usually evaporate that small amount of condensation before it can hit the ground. Doug
Correct (as usual).
38,782 PostsLatest Activity: Aug 11, 2021
