hotjag1's avatar
hotjag1
Explorer II
May 27, 2022
Fuse location on engine a/c compressor
The engine a/c compressor doesn't kick on when activating the dash a/c button. There is no power to the wire that is connected to the compressor. I'm guessing that there is a blown fuse as it has worked fine until this spring. I have checked all fuse boxes and cannot locate the a/c fuse.
I called Tiffin and they said it was in the battery compartment. I found 4 inline connector fuses in that compartment, but they all looked good and they are not labeled as to what they are for.
Does anyone know where this a/c fuse might be on the DP in my signature?
