Richard, thanks for the information on the compressor I didn't realize that that was the method to figure out the exact type of oil. Probably saw why some oil was added to begin with. Interestingly an RV dealer told me that they've seen systems take up to 10 pounds though I believe Doug said my system should only hold 4 lb.
As far as the dryer so you're saying I may need to replace the dryer. I'm supposed to use a wire to replace the dryer or are there fittings that need separated in the system evacuated and all of that? Or maybe you mean to do something with the expansion valve screen. It's my understanding that's all sealed and you would need to replace the expansion valve but is there a way to unclog it or do something with this screen with a small wire? Not sure I completely follow that.
When I say needle now I guess I mean is it a valve stem you know like the little valve stem thing inside of a air fill they look the same in the inner tube or your automotive tire as they do inside of those air conditioners the connector for the low and high side.
Thanks again so much
