Our dash a/c (Evans) stopped getting cold. It all works, blows air and puts it in the right place, gets warm when I ask for heat, just don't get cold on a/c. I verified that the water valve moves p...
The water valve can move properly and still be leaking. Just place a pair of vice grips on the water hose on either side of the valve and block the water completely. This will determine if the problem is the valve. Mine did the same thing. I went to Lowes and installed a hot water shut off valve on the other side of the factory valve. During the warm weather months I shut the valve completely off. During cold weather months I open it up.
