Shifty_P's avatar
Shifty_P
Dash A/C issue
I own a 1993 Cobra Monterrey 30. I purchased it a little more than a month ago. For the first couple weeks. There appeared to be no issues with the Dash A/C. While on a trip last week, I noticed the A/C was not working. Initial troubleshooting determined that the clutch on the compressor was not engaging. Using a volt meter. I drtetermined there was no current going to the clutch solenoid to engage it. As fter checking all fuses, and relays I believed it was the low pressure sensor causing the compressor not to turn on. I bypassed the shutoff, and engaged the clutch using an external 12v source. With the clutch engaged, I was still unable to get the system to take any additional refrigerant. While the compressor was running, the air coming through the vents was also the same temperature as the outside air. I'm not sure what I should look at next. Any help would be appreciated.
