rgatijnet1
Jun 08, 2015Explorer III
Is the fan still blowing any air at all? If no fan at all, that can be a blown fuse, bad switch, or bad fan motor.
Another possibility is a leaking heater valve which is allowing hot water to mix with the cold AC air producing warm air out the vents. This can be checked by feeling the water lines going in to your AC box and see if they are hot. If the valve is leaking, you can clamp off the water lines going to and from your heater core for a temporary fix.
38,763 PostsLatest Activity: Dec 05, 2025
