mabynack
Jun 08, 2015Explorer II
The easiest problem to solve is if the system is frozen. Condensation freezes on the evaporator coils and doesn't allow air to pass through. Shut the system off for about ten minutes and then try it again. If it's blowing cold air, you've found the problem. This occurs from high humidity. I've had it happen in a Dodge and a Ford.
38,763 PostsLatest Activity: Dec 05, 2025
