wa8yxm
Feb 15, 2018Explorer III
Ernest wrote:
Check the oil level in the leveling system. Depending on how you're parked at home if might be showing it low. At the dealer it was OK because the float switch was just making it.
Good luck
At least two Leveler companies using hydraulic jacks use a float valve in the fluid tank to determine "Jacks up" Tank full, Jakcks up
Here is what happens. It's a hot August day. The fluid (Usually transmission fluid) expands FASTER than the tank and the tank overflows.
Today it is Feburary, not nearly so hot, but due to the loss of fluid last August (or perhaps by other means) the tank is no longer full.
