msredneck84
Jan 09, 2014Explorer
First of all, I am no mechanic by any means. But your problem could have to do with the vacuum system that switches the airflow from heat to vents, to defroster etc. If that is your problem, then when you reset your control from say vent to heat it is not switching the vent internally. I had this problem on a GM passenger car once. Just guessing. Good luck!
38,783 PostsLatest Activity: Sep 10, 2026
