GPWayne
Apr 30, 2016Explorer
I had that same problem and more. It would switch cameras at will. Voyager brand monitor. That happen two years ago. After running the heat pump I got the humidity down to under 60% and was surprised when the monitor started working as it should. I now have a dehumidifier set at 60-65% in the MH. That keeps everything in good shape.
The rest of the story.....On the final leg of last summer’s three month tour our Voyager monitor died. (Found that is very common for this model. Tube type monitor.) That model is no longer made. Well, I just finished installing a new Voyager LED replacement. Works just fine. I was lucky to find an adapter kit so I did not have to change cable plugs or cameras. Just plug and play.
38,763 PostsLatest Activity: Dec 05, 2025
