dougrainer
May 01, 2016Nomad
bob b wrote:
Latest update, switching camera inputs left to right to the camera controller makes no difference. The monitor only shows the view of the right camera. The Perimeter view camera controller made by Mito is discontinued. I did check and it is receiving left and right turn signals from the turn signal switch so I suspect the controller is bad? Bob
Is this in error? You stated originally it only showed LEFT and now you state it only shows RIGHT. You should be able to find all 3 camera cable wires behind the monitor. Some, all 3 cables are the same and some, the REAR is different connection. So, you can always swap the Left and Right Camera wires. IF BOTH do not display and only ONE displays you know that camera is bad. Now, IF the rear camera plug is different, you remove the rear camera and disconnect it at the rear hole and then plug it in at the dash plug in to verify its operation. Doug
38,763 PostsLatest Activity: Dec 05, 2025
