Hopefully just a power issue? Our in dash magnadyne is completely dead. No light! Wiring diagram shows a "constant" and a "switched" 12 volt power. I checked both fuses (one in the front run bay, sec...
Thanks guys. I'll try the paper clip trick, verify the power, check the connector. Hopefully today, we pull out tomorrow for the nascar race.
I removed the fuses and tested each is a tester, it lit up. Thought about pulling the meter out and actually verifying voltage, but thinking was it for then.
Never had a lick of trouble with this thing, and actually kinda like it. It has MX, and the buttons and display are big enough that I can see them without my reading glasses!
