Gallifrey's avatar
Gallifrey
Dash Temperature Control: Hot or Cold, no inbetween
Hi,
Now that it's a bit chillier, I've noticed the temperature control knob on my dash is almost either full-on hot or full-on cold. There's a few degrees where I can adjust it between the two, but it's only a few degrees of the full rotation of the knob and it's impossible to get the temperature just right.
Any suggestions on what might be wrong? I'm fairly handy and willing to fix things, but I don't know where to start when it comes to the dash climate control system.
I have a 2011 Winnebago Itaska 32K which has a Ford chassis.
Thanks for any help or suggestions.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    One option is operator understanding error
    There are basically 3 types of temp controls
    one restricts water flow in the heater core
    One mixes air that passes through the heater core with air that bypasses the heater control
    and one::::: IS an actual thermostat that will switch between "VENT" (cold) and "HEAT" (heater) as needed.
  • hikerman wrote:
    You might install a manual water cut-off to your heater core. That may also give you colder a/c in the summer.
    It helped my '04' Newmar WH chassis.
    true sometimes when using AC only but OP is trying regulate the cabin air temp while in heater mode.sounds like the controll switch sends too much vacuum to the control module and its either closed or open and not staying part way
  • You might install a manual water cut-off to your heater core. That may also give you colder a/c in the summer.
  • The cockpit control sends an analog signal to the flapper valve control module. If this module (forward of the firewall) has ever been subjected to moisture (as in condensation etc) it will corrode and fail to operate the flapper valve correctly.
  • Apparently no one ever told Ford Trucks how to build a temperature control that works. Mine have all been the same way, either on or off, no in between.
