bullydogs1
Feb 08, 2014Explorer
The fact that bypass did not work may mean that the low Freon switch is tripped..You sure you have enough refrigerant in there?...I'd start there and have a leak detector put in with it..If compressor starts working that's it..the next thing which the detector will do is to find the leak...Other possibility is a comp clutch but that probably would have destroyed the belt by now.
38,706 PostsLatest Activity: Feb 01, 2025
