campingshadow wrote:
Ok….time to admit I am dumb! Took me forever to figure out the bypass valve was nowhere on the water heater…..or at least the part on the outside of the RV.
Now next stumbling block. It is apparently behind a panel in the bedroom under a closet and drawer. Even has a notice on it saying to remove the panel to get access to the water heater.
How nice. Except the panel has no hinges, no pulls, no screws or any way to remove it except for somehow prying it off. My luck I would try that and destroy the panel or the frame around it.
Someone tell me why I was dumb enough to buy another motor home! Is there a secret in a “guys only” manual that tells how to do this stuff? The one I am with is suffering from some mental decline and is no help at all. Figured getting an RV would be good for him to get out and enjoy before his mind is too far gone. So far have not made it out of the yard! ??????
Have you contacted the previous owner? Are you certain it's behind the water heater? Often they are near the water pump or in the wet bay.
