- Ray_INExplorer IIICummins engine identification: https://qsol2.cummins.com/info/qsol/service/find_esn_tip.print
Caterpillar engine identification: http://www.servicemanualpro.com/locateserial.asp - Bea_PAExplorerI have found when looking at motorhomes that I usually know more than the salesman does unless it is a small family run dealership.
- Sully2Explorer
FormerBoater wrote:
8.3 liter displacement assures you that it is not a 260.
Most mechanical C8.3's were either 300 HP or higher.
The electronic ISC's (8.3 liter displacement) are greater than 300 HP.
The first years of the ISC series...they also had a 295 HP version along with their 330 HP. The 295 was std equipment in my own rig. - jvernonExplorerCummins said 8.3 isc 315 hp/950 lb torque Coach is 26k gvwr so it should run well
- Executive45Explorer III
Tom/Barb wrote:
jvernon wrote:
I looked at a monaco, dealer said it had the 260, i said no thanks. Then they call
and say it has the 315. The owners manual in the coach says 315 8.3 liter isc, how do i know for sure ?
When a dealer doesn't know what the engine is in a M/H I'd run like the wind.
True...we looked at a coach and the salesman raved about the Cummins in the coach, except the engine was BLUE!!!...:S...Dennis - Tom_BarbExplorer II
When a dealer doesn't know what the engine is in a M/H I'd run like the wind. - jvernonExplorerI will call cummins Monday. ive read the 8th digit of the vin indicates the engine. on the rv I want to buy its a 1. I cant find the code as to what 1 represents assuming original engine.
- ScottGNomadDeleted.
- Executive45Explorer IIICall Monaco with the last 6 digits of the VIN. They will provide you with the engine number. Verify that the engine in the coach is the original. Call Cummins with the engine number and they can give you all the information you need on the engine....Dennis
- FormerBoaterExplorer8.3 liter displacement assures you that it is not a 260.
