noteven
Sep 03, 2021Explorer III
mountainkowboy wrote:
Anyone removed the old cracking decals? What gets them off the best?
I am.
I am using a product called VinylOff made by Crystal Tek.
If the decals are not cracked, use normal lift a corner and get as much off by peeling them back on themselves as possible. Then use the product to remove the adhesive. If you apply the product to an old but sound decal it seems to weaken it so it does not peel nice but not enough to scrape nice if that makes sense.
If the decals are cracked, apply the product as per the instructions to the decal. I am using a rag to daub it on and steel razor blades in a scraper to remove the decal material.
I cleaned the area after removal with a rag and alcohol.
I plan to polish the gel coat once I am done removing the decals.
38,782 PostsLatest Activity: Sep 10, 2026
