eheading
Dec 23, 2014Explorer
DEF shelf life
I have read that DEF has a definite shelf life, and I've heard figures of around 6 months. Given that most of us don't use our motorhomes in the winter, or at least like in my case, only on relatively...
Mr.Mark wrote:Wow, if you are getting 6.6 MPG, then you are burning DEF at a 4.4% rate. You may wish to get that checked out. That seems excessive. Are you sure it's normal? Everything I read says 2-3% with 3% being closer to average.
Holstein, I'm getting about 6.0-7.2 mpg from what I can tell. If I keep it at 60 vs. 70.... I can get a whole 1 mpg more at almost 7.2 mpg if the terrain is fairly level without strong headwinds.
I know it takes a lot of miles to get a true mpg average. I haven't weighed our coach yet but was assured that we weigh about 54,000 lbs. wet.
MM.
