Dpsebring's avatar
Dpsebring
Diagnostic center-Freightliner-2006 Coachman Cross Country
I have a 2006 coachman cross country 384ts. After driving for a while I will see my diagnostic center go blank(still lit up) and all of my warning lights(blinkers to low air to brights, to parking break) all of then flash one at a time in a quick 1 second circle and it just continues. It will normally reset when I shut engine and ignition off and start again.
Any ideas out there.
Thanks for any help.
Dan
  • I also think it is power related. On the previous Freightliner Instruments (system III), the lights illuminating as you describe is a symptom of low electric power.
    Freightliner help desk can help. 1 800 ftl help
    Have your last 6 digits of vin number available. It's a free service.
    Fred
  • Check you main power cable from the chassis batteries to the firewall at the front. Our '06 Phaeton on a Freightliner chassis, all systems would shut down completely for 2-3 seconds then everything would come back, all while driving down the road. Problem proved to be main power cable @ the firewall, the factory crimped connector wasn't well crimped...only the shrink tubing was holding the harness together. A swift tug separated the cable from the cable connector that stayed on the firewall connection stud. Replaced the connector and we've no problems in almost two years.
