Quote: Diamond Shield tech used a wallpaper steamer to heat and soften the film then cleaned up behind it with Xylene. The steam will not over heat the film but soften the glue behind it without making the film too weak to pull off in larger pieces.
X2
The Rep. that replaced mine used a steam gun, heating it and pulling it horizontally to the side vs. 90 degrees from the surface. He removed it in big sheets. When pulling it stretches and lifts from the surface. Seems like it took him between 1-2 hours, but that was 5 years ago and I don't recall the exact time.
