Diver4242
Dec 16, 2016Explorer
Diesel Comfort Advantage 30-34 Foot?
I read through the most recent gas vs diesel threads just now, they're all from earlier in the year so I wanted to start a new one with our specific question(s) that aren't clear after reading those.
My wife and I are shopping for a 30-34' rig (it's just us two and we do well in small spaces, not big people) and we may bring a small motorcycle or scooter on our trips (given Uber and other options for getting around these days), other than that no towing. We are in the northeast (NJ) and will primarily be going south or southwest, so not much concern about getting up big hills. We're both still working, so vacations for now but that will lead into hopefully spending the winter months down south in two years or so when we're both done working.
My main question is what is meant by diesel being more comfortable/driveable? I see that comment again in the new On Ramp article by Bob Livingston in Motorhome magazine. Is is because gas is spring suspension and diesel is air? Because of the overhang in the back of gas due to the front engine, and associated noise?
I'm wondering how many of those posts are from folks who tried gassers back in 2000-2001 since a few appeared to be so. I'm sure a lot has changed. I saw the excellent, detailed summary in another thread and copying it below my post here below, but not sure what years that's based on or whether all of that still holds true for our choices. We're looking at used Tiffin, Newell, Newmar, Winnebago, Monaco in the 30-34 foot range, hopefully 2011 or newer. Do gassers in that sector have these issues, since they are higher quality manufacturers?
Also, any recommendations would be welcome :-) Thanks in advance for any help.
Class A gas have: Spring suspension, shorter fuel range (80 gallon fuel tank vs 100 - 150 on a diesel) , and depending on the manufacturer can be very loud. It depends on how long you travel away from hookups. There is no question that diesel engines last longer.
Class A gas pros:
Lots of floor plans available
Lots of inventory
Lower initial cost
May have disc brakes
Class A gas cons:
Poor towing capacity typically no more than 5,000#
Very loud inside depending on floor and doghouse insulation
Longer rear overhang (be careful getting fuel)
More frequent service than diesel
Service centers are typically only at Ford Truck and motorhome shops that have limited hours of operation
Harsher ride with spring suspension (Lots of squeaks and rattles)
Coach systems are not as integrated
May need suspension and or steering upgrades depending on the manufacturer. (Safe T Plus, Roadmaster Reflex Steering stabilizer, etc.)
Lower fuel economy less than 10 MPG is common 5 - 8 is very common in older units (Worse if towing a toad)
Shorter range typically 300 - 500 miles
Smaller tanks (80 gallon fuel is common, 30 - 80 gallon fresh water, 40 or less gallon grey and black, 10 - 30 gallons of propane)
Class A diesel pusher benefits:
Quiet ride with almost no engine noise
Soft stable ride due to full air suspension
Typically have well integrated coach systems
Automatic Generator start (depends on year)
Panoramic front view
Very quiet diesel generator (1800 RPM vs. 3600 RPM)
Excellent turning radius for the size of the coach (a 33’ DP will usually have a 208” wheelbase and a 55 degree wheel cut and can turn around in a standard street)
Fantastic, fuel capacity (Typically starts at 90 Gallons and goes up to 200 gallons of diesel depending on chassis) gives a realistic range of 1,000 miles on flat ground.
Excellent water tank capacity – typically starting at 90 gallons and ending up at about 150 gallons
Other tanks are also usually larger
Well integrated coach systems
More living space for a given coach size
Engine exhaust braking system (Pac Brake, variable vane turbo or other great system) These types of brake systems can hold a coach and toad on a long down grade without using the service brakes
Usually any truck diesel shop can work on them and many are open 24x7
Chassis and drivetrain last a very long time
Long service intervals
Better manufacturer support
Have tow ratings starting at 5,000# to 50,000#, depending on coach some very inexpensive units have tow ratings of 10,000#
Large battery banks (4 large house batteries and 2 chassis batteries)
Large residential refrigerator (less common on older units)
Heated wet bay
Neatly run wiring (Some high end well made gas coaches have neatly run wiring)
Weight ratings starting at about 26,000 GVWR up to 55,000# GVWR with a tag axle with GCWR ratings of 30,000 up to 80,000
Better fuel economy for similar sized units
Class A diesel pusher cons:
Limited inventory
Higher initial cost
Higher cost per hour for service
Typically more complex due to better integrated systems
Limited floor plans (I only found a few floor plans that had bunk beds and a 10,000# tow rating)
Class A gas pros:
Lots of inventory
Lower initial cost
Class A gas cons:
Heated wet bay
Limited inventory
Higher initial cost
