- Fleet_ManExplorerFor those of you who use Howes Diesel Fuel Treatment, check your local Wal*Mart. Ours has Howes for less than $10.00 a jug vs. $16.00 to $18.00 at the truck stops.
- KoopExplorer
lryrob9301 wrote:
The only thing I use is Biobor JF at every fuel fill. 1.5oz will treat 100 gallons and keep microbe growth from clogging the fuel system.
I also use Biobor JF at every fill up. It not only eliminates microbes (humbugs) it adds lubricity to ULSD fuel. - robertbenitaExplorerDiesel Kleen is our choice!
- tmmarExplorerDoes anyone know how long Biobor lasts once the container is opened. I usually only use it when the coach will be sitting for more than 4 months which is usually around the end of the year. If I open the 32oz bottle, I will not use it up for a couple of years so the remainder sits around for a while.
- FormerBoaterExplorerYes
- Blaster_ManExplorerThis debate rages on. However, one additive you should always add is a biocide if you store your coach.
- brireneExplorerDiesel kleen here. White bottle in winter, silver in summer. Boosts cetane, adds lubricity, anti gel in winter.
- DSDP_DonExplorerYes it is. I use OptiLube and here's why: Diesel Fuel
For those that say they don't do it because the manufacturer doesn't say to....here you go: Cummins - lryrob9301ExplorerThe only thing I use is Biobor JF at every fuel fill. 1.5oz will treat 100 gallons and keep microbe growth from clogging the fuel system.
- Pass42ExplorerWe use Penn Ray diesel prep. improves cetane rating, adds lubricity, etc.
38,769 PostsLatest Activity: Apr 03, 2026
