Ivylog wrote:
I've had much the same problem although after 30 minutes it will work for a little while some of the time. I reset my trip odometer when I fill up and I know how many miles I can go before getting low on fuel so I've stopped worrying about it not working since I'm the only driver. I also have a display that tells me how many gallons used and it's always within a few of what it takes to fill up. No way would I drop the tank to fix it.
If you have ever dropped a tank you will not ever like doing it again!
Just either write down the info on a sheet so as to always know what you have in the tank, or fill the tank every time you stop or go, or as Ivy says reset the trip tic, that tank is a PIA.
IVY, has summed it up well.
