Mostovi wrote:
darsben1 wrote:
Rather than consider the original question I have one for you. What are your plans with the rig? Lots. of miles? Stay stationary? Some other answer. Then we might be able to guideyou to a good decision.
I appreciate all of the info. I will be retiring soon and we plan to hit the road, with extended stays wherever we want to be. We plan on doing significant traveling. I had read some threads with comments that gas actually pulled hills and mountains better than diesel, which is what prompted the question.
Based on your plan to hit the road and 'doing significant travel', I would want a diesel. This is especially true if you plan to travel in the western US and through the beautiful mountains.
That said, your focus should be on getting a floorplan that you can enjoy and meets your living needs.
A diesel pusher will also provide benefits in terms of ride comfort, handling, cargo and towing capacity. This may not always be true in some of the lowest cost entry level DP's, but will be the case in many situations.=
