dubdub07's avatar
dubdub07
Diesel Pusher category
Not that this is a "mine is different so it's better" thread, but at a minimum we could get DP on the drop down to better sort the the gassers from the DPs. Not much similar in the two.
WW
  • wolfe10 wrote:
    Dutch_12078 wrote:
    jplante4 wrote:
    I believe most people just watch the "All" category.
    Exactly what I do...
    I do as well.
    Yep, I click on 'Newest' and read whatever interests me.
    If they split Class A into two catagories, shouldn't they do the same for Class B and C? They're made in gas and diesel.
    It doesn't matter to me as long as my forum dues do not increase. :)
    I do as well.
  • magicbus wrote:
    dubdub07 wrote:
    magicbus wrote:
    Having owned both a gasser and a DP I would offer that other than the engine and the brakes they have pretty much the same class A issues and concerns. Maybe under the Tech Issues I could see a different category, but not sure I understand why under Class A.
    Dave
    I have only owned a DP, and I can tell you from reading all the posts it seems the two have quite different issues.
    Maybe it would help me to understand if you could give me a few examples where a Class A DP would have different issues than a Class A gasser (other than engine or brakes).
    Dave
    What harm does it do? It could already be done. You mean the difference between an ISL and a 460? 40,000lbs versus 25,000 lbs? The air suspension, Allison MH3500? I mean, seriously, there are a lot of differences. Mine does not sway going 75mph in a 30kt crosswind, but most gassers are on here trying to figure out how to get rid of sway. Normally, the differences are the DP has fewer issues, fewer posts, and it would be nice to have a completely separate category to help with the sifting. Ideally, a CLASS A GAS and CLASS A DIESEL split would be great.
    WW
  • dubdub07 wrote:
    Dave
    Dave
    Dave
  • Having owned both a gasser and a DP I would offer that other than the engine and the brakes they have pretty much the same class A issues and concerns. Maybe under the Tech Issues I could see a different category, but not sure I understand why under Class A.
    Dave
  • azdryheat wrote:
    Do I understand you to say you want DP's and gassers in separate areas under the heading of Class A Motorhomes?
    Yes, yes, yes.....would not that help things out! The links in the category could just add DP!!
  • Do I understand you to say you want DP's and gassers in separate areas under the heading of Class A Motorhomes?
