- wolfe10ExplorerLighter, smaller, less expensive to buy and maintain.
As said, if you foresee occasional generator use, no big deal. If you use a generator all the time, a diesel generator is better. - Triker33ExplorerA LP generator is much cheaper to do maintenance on. Usually they come with a separate 40 gal LP tank. If you don't plan on dry dock camping a lot. It is not a big deal.
I have one on my MH and it gets most of its hours every year just exercising it every month for 1-2 hours. And a few hours when driving and outside gets above the high 80's and dash AC can't keep up.
If you plan on using a generator a lot. Then look for a MH with the diesel one. - IvylogExplorer IIICheaper and usually not as big as probably a 30 amp rig
- tinkererExplorerCheaper to build. My 98 Discovery had that setup. My 2007 has a diesel. Needless to say I like the diesel much better. But I am sure
I paid for it. If you don't use the generator to much the LP will work ok. ;)
38,766 PostsLatest Activity: Jan 10, 2026
