DaveN
Mar 27, 2014Explorer
Diesel start batteries
My Fleetwood Discovery uses two 950 cca batteries. While checking the batteries current draw I noticed when I turn the ign. key on there is minimal current draw (o.5 dca) but after starting the engine the current draw jumps to 25 dc amp and after a few seconds settles between 19 and 20 dc amps. A steady draw of 20 amps appears excessive with nothing on or running except the diesel engine. The alternator shows a steady charge, the block heaters are off, and a battery charger is not connected . Grounds appear to be good. I'm using a clamp-on amp meter in good condition. I would appreciate your advice and/or comments.
