valhalla360 wrote:
If you are comparing apples to apples, it's one thing.
The issue is it's rarely apples to apples.
The big diesel pushers compared to front engine gas MH's are usually wildly different beasts.
  What size MH are you looking for to fit your camping/traveling style? If you want a 38 ft to 43 ft MH go with a DP if you want something smaller say 30 to 34 look a gas MH. It is not an apples to apples comparison. A gas MH will have the same engine from 28 ft to 39 ft. A DP will have smaller engines with less HP and torque in the shorter MH's. A 40 ft DP may have 350 HP and weigh 30k lbs or more and a 30ft gas MH may have 362 HP and weigh 15k lbs or less. That gas MH will have greater performance on hills and a flat slab than the DP. Very short DP's are very hard to find used but there are many 40 ft DP's for sale.
