lacofdfireman's avatar
Jun 05, 2014
Difference between Ducted and Non Ducted when buying AC?
Besides the obvious of one being ducted or non ducted I am trying to decide where to buy a Ducted A/C unit if I end up having to replace mine. When I call Camping World or someone like that to get prices for a new roof A/C unit when I tell them mine is ducted they always tell me that's a special order. What is the difference between the units? I realize one just blows straight down and one blows down and around the ducts but what makes them special order? I would think any RV built in the last 10 years will have a ducted system so why would they not stock a Ducted A/C?
I am looking at replacing my Dometic Duo Therm Model 57915.541 out of my 2007 Georgetown 351DS if I cannot figure out what's wrong with it in the next few days. Also wondering if this may be a heat pump also as the wall thermostat for this unit runs the Heat in the Motorhome also.
When I am looking for a replacement unit what specifically do I need to ask for? Can I just go off this model number? I would assume it has been upgraded over the years. Plus I would like to probably go to a 15000 unit instead of another 13.5.
Also as far as installation goes is this going to be a lot harder of an install because of the heat and ducting compared to a non ducted unit? And can I still use my current thermostat or do I need to upgrade that also. Here is what my current thermostat look like..
  • Not a heat pump. Heat pump, cool, heat, off, furnace. The ideal unit is ducted with dump grill.
  • Get a 15k unit ducted...it's the only way to go. You'll never be sorry you bought it.
    We replaced the 13.5 with the 15K model.
    Now the 5th wheel gets uncomfortably cold if we turn the thermostat all the way down. With the 13.5 it was tough to get it cold enough to be comfortable.
