steveownby wrote:
Jim & Betty wrote:
Not wanting to Hijack Thunder Mountain's post I had a question about the differences in the Michelin tires.
I looked on the Michelin web site and found two RV tires in my size 275/80 R22.5 load range H one was a XZA3 and the other a XZE. From what I read the XZA3 can be retreaded and was, from what I understood a steer tire. So what is the difference?
I will buy Michelin only and I do appreciate other opinions but please no pitches for other brands, Thanks.
I am looking at all six all position tires so if ever needed the fronts can go to the back and the backs to the front. I have had to do that with the Goodyear tires on the RV already.
I have the Goodyear G670s that are starting to river and will be 7 years old at years end so I am looking to buy between now and Spring (within 2500 miles and 7 months)
Thank You for the reply
JimR
Hey Jim,
In Michelin brand, you are correct that you are pretty limited in choice. Personally, I would go with the XZE as they are a regional haul design and have a stronger, moe protected sidewall. They are also rated as all position. If you have room in your wheel well the 295/80 in the XZA2 Energy is a great motorhome tire.
There are only two tires marketed specifically as RV tires, the Goodyear G670 and the Michelin XRV. The XRV is not made in your size. Both have had issues over the years and personally I would always prefer a all position rated truck tire.
Hello
Yes I am leaning towards the XZE I have seen them on other rigs and the drivers seemed to like them. Thanks for the replys
And Yes I am a FMCA member and would use the program if it saves money.
JimR
