valhalla360 wrote:
klutchdust wrote:
PartyOf Five wrote:
He said when the particulate matter in existing fluid will, when replaced, make the seals/ gaskets the "weakest link" & they may fail more readily. Let a sleeping dog lay.
That's a new one. I do know this. A transmission "flush" is the worst thing you can do to your transmission.
Jerry was in business over 30 years, replaced many a trans just after a flush. Want piece of mind, don't flush.....your tranny that is....
I think there is confusion with the transmission.
In a transmission, the fluid does other thing including creating specific levels of friction...and the common response is don't fix it if it's not broken.
The rear diff is a much different animal. It certainly shouldn't cause leaks.
I responded to the comment made that 'If you were to change the fluid it would make the seals the weakest link" At least that is what iIunderstand the OP to be saying.
Having spent my career wrenching on just about everything, i can say that I have not seen a seal leak in a differential after the fluid has been changed.
What I have come across is the fact that transmission flushes have a direct link to transmission failures. Drop the pan, replace the filter, clean the magnet and refill.I referenced my buddy who ran a shop for 30+ years.
What many non mechanic type folks are lead to believe is that your car/truck RV needs flushing. Flush the radiator, brake lines, transmission.
Has anyone ever had a brake failure because their brake fluid failed? I cannot find any mechanic that I know that has seen that happen. Yet go into a jiffy type place and they swear you are in danger if you do not get it done.
So, I tell my family that regular maintenance using quality products on a consistent basis is the best warranty out there.
It's interesting that a differential failed with less than 20K miles on it. That is a rare occurrence. Maybe an outside bearing but the differential, that's odd.
Safe travels folks and change your oil.
