enblethen wrote:
OP: you need to recheck the distributor. rotate the engine to number one cylinder, align the timing mark on the vibration damper. It may be off one tooth.
Installing distributor can be tricky! the oil pump shaft doesn't always drop right in meaning the engine needs to be turned over one direction or another. Best to do manually with bar on crank or if lucky with serpentine bely.
I verified the harmonic balancer is good and has not slipped. I posted it earlier in the thread but I took a 1/4 extension and slipped it into the spark plug hole on the number 5 cylinder, then rotated the engine until the extension was jammed in place by the piston coming up. I then checked the balancer and found it approaching 4 degrees BTDC, so the balancer is safe to use as a timing mark. That's how I got it running again. I have adjusted the timing by ear by turning the dizzy to where it will crank when you just bump the key and it will start hot or cold, which is a big improvement.
However, it's still running rough and pig-rich. That's why I want to verify all the sensors and get a timing light on it to really get the timing as precise as I can.
Based on how it runs it may be down a cylinder so I still need to verify that as well. When I changed out the spark plugs the plug that came out of cylinder 7 was pretty fouled with oil, so the oil control ring on that cylinder is pretty worn out. That one might be down.
It also looks like at some point in the RV's life the catalytic converter was removed. The O2 sensor is still there, but I don't see the cat. That could also be a piece of the lovely smell problem coming from the exhaust.
I haven't done my audit of electrical grounds yet, was focused on getting it running. I agree that bad grounds cause strange behavior. I had an Outback that was a crusty northern car and it ate headlight bulbs and shifted really rough until I cleaned all the grounds. The battery cables can probably stand to be replaced, but I'll get there.
I also need to go through the general wiring as the electric fan on the radiator doesn't seem to be running once the engine gets to temp and it sounds like the mechanical fan needs a new clutch. I also haven't seen the tiny engine bay cooling fans kick on either. Plenty of work to do in order to get this one sorted.
Does anyone know what color spring is needed for the 94-95 FPR? I can find plenty of kits with springs that claim they work for 94-95, but they also claim to work all the way back into the 80's model years so I don't know how that is possible with the change in fuel pressure in 94-95.
As long as you guys are willing to offer wisdom, I'll offer updates. This is my first GMC engine and chassis so much for me to learn here.
