Gonzo42
Mar 27, 2016Explorer
I find that it is important to go throught the syncronization procedure each time I set up the BB. If you don't have it or the manual I can reprint it for you here.
In addition I press the initial setup button which causes the BB to actuate 5 times. This lets me run to the back of my toad and verify all my brake lights are working.
As I have it set up, the Toad weighs in about 2700 lb and the manual says 40 psi but I find it works better at 45. Also a conversation with the rep says that I should set the sensitivity on level roads at a low setting but on mountainous roads much higher.
I have mine set at 6. When I brake my MH lightly or moderately the BB does not actuate, but a firm pedal will cause the BB to actuate, and the remote light tells me it is working.
38,769 PostsLatest Activity: Mar 31, 2026
