I have a 2018 Minnie Winnie 33 foot with a V10 I want to tow my jeep wangler 5000LBs from NC to Kentucky the mountain in Ashville is steep will my rig towed this ok or you think over heating will be a...
If you know how to select a proper gear for the grade, overheating should not be a problem if you are not exceeding the GCVWR (gross combined vehicle weight rating). I've towed my 4Runner over 12,000 foot passes with my '03 Winnie. Mine is 24' so I have a lot more of the GCVWR that isn't consumed by the motor home gross weight. You need to weigh the motor home and the jeep then do some simple math to see where you are.
