Look in your receiver set up menu for the satellite set up. If the menu options allow you to choose the dish type, set it to 18" round dish and the switch to multi. That should allow you to get your channels but on standard definition only. Set your dish to pick up the 101 satellite. If the LNB is still working, you should be in business. Our HR24 DVR can be set this way if we use an 18" dish instead of our Trav'lr when trees block the roof. You'll have to go through the entire satellite set up on the receiver but it should work. Not sure about the new Genie's. Chuck
