- peaches_creamExplorer
Bill.Winegard wrote:
A lot of confusing info above. The HR34 is SWM only so the suggestion directly above will not work. You can use your 18" round antenna with the Genie but you will also need to add a SWM8 kit to the mix. You will also only receive the DirecTV SDTV programming while using that setup.
The SWM8 switch will also require the PI28 or PI29 (power inserter) and not the black power inserter used in your home setup.
You can get info on how to setup the SWM8 kit here:
http://www.winegard.com/kbase/upload/2452242.pdf
Bill, you are probably correct. I confused my H24-100 with the H-34.
Sorry - Bill_SatelliteExplorer IIA lot of confusing info above. The HR34 is SWM only so the suggestion directly above will not work. You can use your 18" round antenna with the Genie but you will also need to add a SWM8 kit to the mix. You will also only receive the DirecTV SDTV programming while using that setup.
http://www.winegard.com/kbase/upload/2452242.pdf - peaches_creamExplorer
Luke Porter wrote:
Can I run a DirecTv HD HR34 receiver on a single LNB dish? I've found where I can select a 18" round dish, but it is looking for the SWM--which the dish doesn't have.
After you select 18" round on the receiver, tab down to the SWM and change it to Multi-switch. Mine works great then. Course it is not HD but still a good picture. - edatlantaExplorer IIThe Slimline dish can be SWM with the correct LNB. I have one.
- sdianel_-acct_cExplorerhttp://www.thesatelliteshop.net/directv-antennas-c-810_691.html
DirecTv HD HR34 not compatible with Slimline dish. Need an SWM dish or other receiver type.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
