ksg5000
Sep 18, 2020Explorer II
Water can only get into the bowl through the toilet valve (or someone peeing) ... maybe the valve is leaking and needs replacing? Since the water supply to the toilet come from your FW tank any water should be clean ... if it's dirty then you should sanitize your FW system ... lots of threads on that subject ... use the forum search feature.
Hope this helps.
Hope this helps.
38,778 PostsLatest Activity: Jun 06, 2026
