Old-Biscuit
Sep 18, 2020Explorer III
Toilet has a vacuum breaker (small container with hole/flapper at top)
After toilet is flushed the flapper opens an allows the water in vacuum breaker to drain down into bowl
As noted:
Should leave water in toilet bowel so seal doesn't dry out and the water is a Vapor Barrier so black tank odor doesn't come back up thru bowel
Should also put 4-5 gallons of water BACK into black & grey tank so bottom stays wet...keeps stuff from drying out/sticking/stinking
YES...there is some stuff left behind even when flushed
As noted:
38,778 PostsLatest Activity: Jun 06, 2026
